Late A aluminum rear end cover.
3408 CAT
Just bout a tractor that has one one it.. my question is. How do you check the oil in it ? It don't have a check plug..
Be careful with those hitches if you have more than 300 hp.--Or a tractor that coughs!---Tee
MIKE!!!!!
If the bolts go through the housing ,just pull the bolt that matches the level you need. If the bolts do not go
all the way through, pull the cover and drill a small hole down the center of a hole.
