any 4 7/8 Case L/LA kits for sale
Ole CC
Looking for a 4 7/8 overbore sleeve/piston set for Case L/LA. Would be interested in just pistons also.
Just suggestion , contact Wisco in mentor Ohio , talk to Sue about making your pistons . I had to for the Fordson.
Also the crank and rods If Babbitt , ask harts in cicel ,Ohio
Good luck , 🍀 I don’t see anything for case l , but harts might have a source for kits it , not fimilar case at all .I tried
When I look for a piston, I go to our local speed shop. He has a book with pistons for everything. Know your pin height diameter pin size. Etc. You will want less if going to stroke it. Say you were going to stroke it 1/2" would need 1/4 less pin height. You also need at least 10 to 1 compression 12 to 1 better. I have spent over 2 hrs looking. But there is has always been one in there.
Moline pistons are really close
