Sigourney pull
MSD
Hey Big Tee, you going to make it to Sigourney this weekend?
HI MEL--I read your results of your pull out is SD and should stay home--BUT--We will be there...It is supposed to be in the high 80's or low 90's Fri and then cool off for Sat. Do you remember how hot it was last year--the cement sweat in that one building was running out the door! We have another pull on Sun. 50 mi. NW of here so it will be a full week-end. Will see you Fri--be easy on us this year--your turn to by the steaks---Ray's Dad
Changed valve stems on the VAC so Abe is ready for Sigourney!!!!
I took there side shields off the G and put new decals on it so it looks a little different now. Hope it runs as good as the VAC.
Looks good Mel--Are you going top cut or full cut the pro pullers? What size turbo are you going with-5 X 5? Now can you get down to the 500 lb. class?--Good Luck--But I think ABE will eat that little Deere up and turn it to Eagle Poop---Tee
I think Ole Abe flew the coop and is going green! Must not have been able to take all the dust from following the Deere's down the track. LOL. See you FRi.
