Company Logo Shop Now
Case 311b
Ethan1
08-05-2020 12:22:52
Hey guys I have a case 311b that I would like to set up for pulling but I am not very familiar with case i was hoping to get some advise on what I could do to make it pull better like hitch setups, tire size and types, and some engine mods from little things to major engine work I will start out farmstock but I will build bigger as time goes on thanks in advance!
mEl
08-27-2020 04:34:05
 Re: Case 311b in reply to Ethan1, 08-05-2020 12:22:52
Not a direct bolt in, the block has to be redrilled, It is a bit of work to get it right, there are starter issues that must be addressed. Have done several and can tell you if the tractor is set up with big tires and a good hitch even that engine is marginal for power in stock form on a good hard pulling track.
VicS
08-05-2020 19:07:31
A motor from a case combine will be a good place to start. 65 hp or so to start. Don't remember what number of combine. 38" rims. 15.5 tires. Get rid of all hyd. Including 3 point all of it. Above all have fun! Lol Vic
Ethan1
08-05-2020 19:51:20
 Re: Case 311b in reply to VicS, 08-05-2020 19:07:31
Ok man I appreciate it! Maybe I can figure out what combine it is lol
VicS
08-06-2020 12:51:31
 Re: Case 311b in reply to Ethan1, 08-05-2020 19:51:20
It's a late model 660 201cu. Early 188 same as a 530 . Block should be a inch longer than yours.
Ethan1
08-10-2020 04:00:03
 Re: Case 311b in reply to VicS, 08-06-2020 12:51:31
So a 201 or a 188 diesel will interchange?
VicS
08-10-2020 17:31:34
 Re: Case 311b in reply to Ethan1, 08-10-2020 04:00:03
Yes. But gas easier, cheaper and will make more hp. That said I pull two Diesels.
Ethan1
08-20-2020 06:49:45
 Re: Case 311b in reply to VicS, 08-10-2020 17:31:34
Oh ok so will it bolt right up or will I have to change some things?
Copyright © 1997-2020 Yesterday's Tractor Co.
