560 hydraulic pump gear
When you remove hydraulic pump can you remove the big gear that turns the pump or is that the only way the bearing can get oil. Looks like that gear would be how the oil would get up to the bearing on the input shaft bearing. Any info is appreciated
I left mine in, seemed like I needed it carry oil somewhere. Ask my buddy and he said he left his in also. Thought it needed to stay also.
