Impatiently waiting
VicS
Location
SE Il.
Think they are good to go. D17 Needs
painting but that is this winter, I hope.
Ran good at Russellville Ky. But needed a
better driver. Maybe It'll shed 50 more
pounds by time this Virus is whipped.
So far so good. It has made it down the track 6 times. Didn't have any trouble. Just have pump set on 3000 rpm. And 250 plus hp. There are a lot of mean tractors out there. I haven't got the balance yet. I was running constantly heavy on the front. Think I should have not pulled it open at the end. 6 and 8 mph. Classes. My buddy won and he just helt his throttle about 3/4 and let it pull down at the end. It weighs 4040 with me and 2 big batteries. Like to get below 4000. And I can eventually. How are your Project's coming along?
I?ve put a set of cuts on the oliver and a redone injection pump to get some more power for 6 mph class.patiently waiting, may not get to pull much this year. How close do you get to ohio to pull? You ever going to try harrisburg out?
Yes would like to go to Harrisburg again. I went the year it was called off because the fumes got so bad. But I got to pull since I was First and second class of 5 mph. Some how the little 435 made a full pull in the 3500 along with a 350U He won the pull off. But I won the 4000. And it powered out! Sometimes its your day.
