Company Logo Shop Now
TractorLinks.com
Farmall 460 axles
shot560
03-31-2020 04:04:54
Good morning, does anyone pull a 460 with the smaller 2 1/2 inch axles? And if so what classes? Thanks
Whiskey Bent
04-04-2020 08:58:47
 Re: Farmall 460 axles in reply to shot560, 03-31-2020 04:04:54
Check the serial number tag to see if the rearend has been updated, they were supposed to stamp a triangle after the update was done.
shot560
04-04-2020 15:51:21
 Re: Farmall 460 axles in reply to Whiskey Bent, 04-04-2020 08:58:47
Yep I checked and itís not there. Believe it or not Iíve looked at several early model 460,s and 560,s and Iíve never seen that stamp to show it had been updated.
Heavy Puller
03-31-2020 17:28:27
I have on 2 different 460ís 3750-6500 lbs . The axle isnít the weakest link in the driveline.
shot560
03-31-2020 18:15:46
 Re: Farmall 460 axles in reply to Heavy Puller, 03-31-2020 17:28:27
Ok thanks for the heads up. If thatís the case what parts would need to be upgraded?
Heavy Puller
04-01-2020 19:45:00
 Re: Farmall 460 axles in reply to shot560, 03-31-2020 18:15:46
What kind of hp are you planning on having and classes?
shot560
04-02-2020 06:27:55
 Re: Farmall 460 axles in reply to Heavy Puller, 04-01-2020 19:45:00
I was thinking of upgrading to a stock 291. 6500-8500 lb class. 3 to 6 mph. Antique or farm stock
Heavy Puller
04-02-2020 16:50:53
 Re: Farmall 460 axles in reply to shot560, 04-02-2020 06:27:55
You shouldnít have any issues with that.
shot560
04-02-2020 17:23:15
 Re: Farmall 460 axles in reply to Heavy Puller, 04-02-2020 16:50:53
Thanks. wasn't sure if it would hold up to the increased HP and heavier weight classes. and since its a 58 and low serial number not knowing if it had the updates done.
Bob 7337
03-31-2020 09:35:37
I would like to find small set of axles. Would like to pull 4250
VicS
04-01-2020 08:06:26
 Re: Farmall 460 axles in reply to Bob 7337, 03-31-2020 09:35:37
I have a friend can pull 3750 with a 460 utility And it has a RD engine. His axles are pipe.
Copyright © 1997-2020 Yesterday's Tractor Co.
