Farmall 450 camshaft specs
Intake opens 5 degrees before TDC
Intake closes 41 degrees after BDC
Exhaust opens 42 degrees before BDC
Exhaust closes 10 degrees after TDC
farmhills : At what lifter lift are your degree marking taken at? must be at WAY less than the typical .050 inch lift where you considered the valve either open or closed
