New Crank!!!!
big tee
Hey Mel--I see your boys are working on your new crank--Are they going to take a torch and cut the extra throws off so they hit your rear tires???---Tee
Mels "stock" crank....
Probably work with 16-9's. Heard there was a big turbo going in a Case somewhere so I thought I might put one on mine too. Should be able to make that crank spin with this one.
Need a bigger turbo than that--Hope I can still make the 5000 lb. class with my new motor---Tee
Gonna need to do a little body work to fit that in. Might be a little heavy on the front.
Another fun fact. Ben was the first to do experimental work on the electric turbo's that are used today. Wonder if one of those would work on my G?
