Company Logo Shop Now
TractorLinks.com
Pistons for lp head
Farmallhm44
01-21-2020 16:05:10
I bought a new lp head for my 44 M. When I took the old head off I found fire crater pistons. Will they work with the new head or will there be other issues because of too high of compression?
johndeerelane
01-26-2020 13:41:18
 Re: Pistons for lp head in reply to Farmallhm44, 01-21-2020 16:05:10
I just put an lp head on my 400 with 281cid fire craters. It has 220# cranking pressure. It also has murphys roller rockers. We are going to put it on the dyno in the spring and tune it. Running 100ll fuel in it right now.
mmfan55
01-22-2020 19:03:23
Biggest issue with higher compression is need for higher octane fuel to prevent pre detonation. After getting the engine together, check compression. 200# and under should run fine on premium pump gas with maybe some octane booster. Over 200# may take some experimenting with blending some higher octane fuel or running higher octane to avoid pre detonation.
dblair
01-22-2020 06:48:52
flat top pistons will get you 223 static, firecraters 197 that says everything you really need to know . flattops will yield about 70 hp if tuned correctly
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
