Company Logo Shop Now
TractorLinks.com
Boring/ crank question
38johndeereG
01-10-2020 07:21:39
Putting .125 over pistons in a 38 G. Heard that we could put a new style G crank in it to get a little more stroke? Have a crank here so not going to cost me a ton to do. If Iím able to do that what rods would I have to put in it? Any help would be great thank you!
Earl-IL
01-27-2020 17:47:49
 Re: Boring/ crank question in reply to 38johndeereG, 01-10-2020 07:21:39
You have to off set grind to get more stroke
6cylpower
01-13-2020 07:24:10
Are you going tractor pulling or just looking to have a good runner around the farm?
Also consider a new cam grind and distributor work if using one.
Is it hand start yet?
38johndeereG
01-13-2020 10:42:13
 Re: Boring/ crank question in reply to 6cylpower, 01-13-2020 07:24:10
Itís a hand start. Lookin to build the tractor for the ďfarm stockĒ just a little bit of motor work without having to stroke it and adjusting to all the major changes. Donít want to dump 20k in it. Just looking for thoughts from everyone
Lynerd
01-11-2020 08:06:49
38johndeereG Offset grind it to 3.000 and use 60 rods for .375 more stroke. 430ci to 453ci. Lynn
38johndeereG
01-11-2020 15:48:50
 Re: Boring/ crank question in reply to Lynerd, 01-11-2020 08:06:49
Lyn is that with just the stock block with removing 3.000 on the crank? Or if I was to remove stock 38 block and put a new style block to and add 60 rods?
Lynerd
01-12-2020 06:20:48
 Re: Boring/ crank question in reply to 38johndeereG, 01-11-2020 15:48:50
38johndeereG What you are doing is grinding the crank from 3.375 to 3.000. This gives you .375 more stroke. The block will not make any difference is motor size. The later block will give you more compression. You get roughly 5.0:1 compression with aluminum pistons on Unstyled G. Around 5.5:1 with stroking crank to 7.375. Can't remember Styled block length but if .750 shorter will give you little over 9:1 compression. Lynn
6cylpower
01-10-2020 07:36:05
Same stroke with either crank. A styled block (shorter) will get you more compression and power though.
mdross
02-12-2020 04:36:46
 Re: Boring/ crank question in reply to 6cylpower, 01-10-2020 07:36:05
Keep in mind the more compression the harder it will roll over to hand start. I'm thinking the same thing with my 70. It's amazing what one point in compression makes blasting out the exhaust when running.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
