Oliver 77 vs 880 weights
KFFarm
Does anyone know the weight difference between the Oliver 77 and 880 tub? Additionally is there a difference in the weight of the rearends? If so, how much difference, and I d presume the 77 to be lighter.
Looks like no wants to tell you. But a old
77 is lighter than a later one. There is
3500 lb. 77's also 3500 lb. 880's but
Imagine they are 77's under the tin. Just
gaining a few rpm. No reason to pull a
88.
(quoted from post at 12:45:16 12/20/19) Looks like no wants to tell you. But a old
88.
Thank you!
47 and 48 weigh much less
There are several differences between a 77 and 880, first off about 1,500 lbs. drum (early 77) vs disc brakes (880), 77 tub (only holes for monunting cultivator) vs 880 has mounting pads,
Transmissons are heavier on 880 and can be helical gear on later ones vs straight (spur) gear on 77. Axles are smaller on 77 vs 880. Dash and hood are not interchangeable. Their are more differences too many to list.
