Company Logo Shop Now
TractorLinks.com
Re: Allis G262
VicS
12-03-2019 06:57:58
You can gain maybe a little. But to really make power. Have to turn it 7000 rpm. Or make it 450 or so cubic inch.
Fullpull2019
12-03-2019 17:16:02
 Re: Allis G262 in reply to VicS, 12-03-2019 06:57:58
Iam wanting to get to 100+/- Hp which Iam told well happen with the stuff Iam doing to the engine.Can not dyno it I removed the pto.Other pullers may notice 7000rpm when the max I can run is 3000.Not sure it is possible get a G262 to 450 ci.
VicS
12-04-2019 18:09:26
 Re: Allis G262 in reply to Fullpull2019, 12-03-2019 17:16:02
4" x 6" makes 415cu. There is a lot of small (honda) big end rods out there for small block Chevys and Fords. Some a little bigger than 4" I have used cheap smog pistons in a AC. Had to cut the dish out round. Cut a dowell rod same size as main bearings. Then cut another one to fit inside your honda big end. Cut a 1/8 x 1" flat iron 3" long. See how much you have to grind to get it to turn. Don't forget the cam. I've seen some pretty radical cuts on cams. On my AC I've ground on rods and the cam. Plus ground block 12 times. Cc your combustion chamber, so you know pin height and rod length. Or go to a tractor puller engine builder. I've worked 3 yrs on my D17 and Had engine out 3 times and getting ready to do it again.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
