Repower super c
mark20
Looking to repower a super c for fun. Original motor is shot and the tractor isn t much good except for parts . Anyone have an suggestions?
There are 135ci & 153ci IH engines found in power units and combines that will be a direct bolt to your bellhousing. Much discussion on this has
happened on here just search the forums you should find plenty of info. Two things to watch... First,there were also 135 & 153 that have a different
bellhousing pattern. Second, you will have to drill the flywheel on some of these as there is no where for the pilot bushing/bearing.
