COCKSHUTT 40 buda 230 engine
I see a lot of information on the Buda 262, but we have a Buda 230. Is there a lot that we can do with this engine to get more horse power out of it??? I?m Not educated on this engine. Is parts available for this engine?
Thanks for any information you can provide.
The 230 was 3 7/16 bore an 4 1/8 stroke. The 262 is 3 9/16 and 4 3/8 stroke. The 230 has a chamber in the head and the 262 head does not. The 262 can be built and gain some hp. Mike Lepard can set you up with pistons. [email protected]
Not sure but original was 3 7/16 bore and possibly cast iron pistons. However most after market rebuild kits used aluminum pistons and sleeves with a 3 9/16 bore and possibly higher compression. You won't know for sure what you have until some disassembly is done. Most likely this engine has been rebuilt several times in the last 60 or 70 years and what is inside is unknown.
