HawkMotorSports
My family has been pulling since the 80's And have had Our fair share of tractors "believe me" This is my Oliver 770 and my brother sears custom 10xl he has had for 11 years I was wondering what else I can do to lose weight on my 770
Loose the Hydraulic unit. You can get the flat plate and shifter mount that goes with it, (external_link.com), or you can strip the top and pump off of yours and make a plate for the top. If it's the aluminum base that's what I'd do. You can lose 15# by replacing the cast iron outer brake plates with aluminum. I'm with RCP on the hub idea. We made our own and maybe lost 80--100 lbs. You might consider going with a Fleetline frame. I don't know how much but it has to be gobs lighter. gm
