Don't look like G to me!!!!
big tee
Brian Raml drove my Case in the 5000 lb. class at Sigourney 2 weeks ago--He was camera shy but I got him anyway! Did a GOOD job--4th out of 40---Ray's Dad
VAC????
Thanks Ramls--Have some new good friends!!!!!!!!!!!
Hey Ray's Dad, we enjoyed your company at Sigourney also and are looking forward to meeting up with you again. The best part of tractor pulling is the friendships you can make at a pull. Nice picture by the way.
Brian looks good on a Case...4th out of 40 is good.....Do you recognize those rear rims on my 1466 IH puller?Finally finished it up today and will hook it for the 1st time Sunday eve...It may go 3 ft or 300 ft.....I could have hooked tomorrow night at Clinton,MO but decided to go to the big Oliver show at Emporia,KS...Should be 300 tractors there and featuring Detroit powered Olivers...Probably will get to see some Detroits plowing at 10 AM tomorrow..
Looking good 1206!! Those rims look better red than primer brown when I had them-Hope you have enough power to spin the centers right out of them-Hope my welds hold. Have a good time at the Oliver show-must be you aren't taking your 1950...Bought me a 1900 a few weeks ago! GOOD LUCK---Ray's Dad
(quoted from post at 19:24:01 07/12/19) Brian looks good on a Case...4th out of 40 is good.....Do you recognize those rear rims on my 1466 IH puller?Finally finished it up today and will hook it for the 1st time Sunday eve...It may go 3 ft or 300 ft.....I could have hooked tomorrow night at Clinton,MO but decided to go to the big Oliver show at Emporia,KS...Should be 300 tractors there and featuring Detroit powered Olivers...Probably will get to see some Detroits plowing at 10 AM tomorrow..
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto29353.jpg">
1206SWMO, they won't let you put some rear tires on that 1466 down there?
10,500 MSTPA Hot Stock rules are a maximum of 20.8x38 uncut or 18.4x38 cut tires....The 2018 points
champ was a 6030 JD running tires just about like mine with just a little less tread..I cant run the cut 24.5's
on 27 inch wide aluminum rims that came with my 1466 puller..
Nice 1900 Ollie...Today at Emporia,KS I had a chance to plow with a 4 valve head 1900 Ollie Wheatland with 3 pt and 3 bottom Oliver rollover plow..I took about 200 pics there today and will try and get some on here in a day or two..Plenty of Detroits there..
Thanks 1206--It is one of those paint jobs that look better 100 ft. away-We know preparation is 95% of a paint job and it must have been hurried. Took the red weights of first thing and made a different pipe for it-new seat ordered and steering wheel--it will be one you can have fun with instead of a Trailer Queen! Looking forward to your pictures and hope someone will take some tonight of you at the pull--Good Luck---Ray's Dad
I used to pull them on a 1456 IH and they did OK....I had pullers wanting to buy them all the time..Heres an almost identical set winning the 10500 Hot Stock last night at Clinton,MO..
