Been through this governor repeatedly. New bearings, repaired holes in weights, weight radius' smoothed, No binding, different linkage adjustments, shafts, bushing, weights(never anything other than stock). If I unhook the carb linkage and operate by hand the governor seems to operate as it should from idle to full throttle, doesn't feel like it has a dead spot. with linkage hooked up mid throttle and lower seems to be near immediate response. But when rpm's are set to 10% over I consistently loose 200+ rpm before it reacts. If I leave my throttle stops adjusted way out so I control the throttle it hold s rpm's great, so not under powered. Does the effectiveness of the weights change as they travel through their arc and I'm just in the dead zone of it? Not trying to reinvent the wheel here. There are plenty out there that sound like they don't drop a bit. I have done the same work in my other Deere's with no issues like this. Any fresh ideas or tricks? Thanks in advance.
