301 balancer in a 560
IN560
Anyone know if I can run my c301 combine balance with a stick 263 cover and be accurate on timing and since it?s bigger will it be a clearance issue cause the balancer is bigger diameter once it?s in a 560. Thanks for the help
The pointer on the 560 cover will not clear the larger balancer, plus the location of the pointer is not the same so your timing marks will be way off. I turned mine down to the same size and then cut 3 or 4 new marks that matched up with the 560 balancer. Works just fine. Lee
