Company Logo Shop Now
TractorLinks.com
310 in Oliver 77
4010 puller
01-09-2019 08:39:00
Hi guys Iíve got a 77 needing an engine and found a cheap 310 gas, whatís involved in doing the engine swap?
chucksoliver77
01-26-2019 19:58:07
 Re: 310 in Oliver 77 in reply to 4010 puller, 01-09-2019 08:39:00
[quote="chucksoliver77"](reply to post at 22:52:42 01/26/19) [/quote
I also have a radiator that is modified for the 310 with bigger inlet and outlet with a fresh recore that I no longer need, if you are interested email me. Chuck
chucksoliver77
01-26-2019 18:52:42
I didn't cut anything when I put a 310 in my 77, just slid the engine ahead and drilled new holes in the tub and block and bolted it in, also had the water pump shaft shortened, slid the radiator ahead as far as you can, drilled new holes in the radiator shell and bolted it in and the side covers closed with the stock 310 oil filter. The pto and hydraulic worked fine. Just make sure the engine is lined up correctly before you drill.
Abuck
01-24-2019 07:33:24
I didnt change any steering rods used same water pump different fan small alternator cut the front of input shaft off drilled new hole in front of it. Everything else fit good. I have done this a few times
4010 puller
01-26-2019 18:17:16
 Re: 310 in Oliver 77 in reply to Abuck, 01-24-2019 07:33:24
How much needs cut off of input shaft? If using pto does it need shortened too?
Cody
01-14-2019 08:48:36
just sell me the motor.
VicS
01-14-2019 09:32:21
 Re: 310 in Oliver 77 in reply to Cody, 01-14-2019 08:48:36
Cody, A guy like you needs to start with a 426 block. LOL
curt smith
01-09-2019 17:13:30
You can run electric fan on front side to allow room for stock pump. I cut the shaft on pump off for more room. Cores are worthless. Spin on oil filter base is expensive but allow side shield to close. Single wire alternator is small and will fit easily. Most use 88 bell housing etc.
VicS
01-09-2019 11:48:55
My son put one in his. Had to make new steering rods. Just used 1/2 black pipe and 1/2" knuckles from a socket set. The water pump is to long. We took it off. Used a electric pump. All the bellhousing stuff will swap. Put a button clutch in. Clutch was a chevy or ford.
4010 puller
01-10-2019 13:07:00
 Re: 310 in Oliver 77 in reply to VicS, 01-09-2019 11:48:55
What about main shaft from clutch to coupler, does it have to be shortened?
VicS
01-11-2019 04:23:09
 Re: 310 in Oliver 77 in reply to 4010 puller, 01-10-2019 13:07:00
He did use a 88 bell housing and flywheel I think. But coupling worked.
4010 puller
01-11-2019 18:03:33
 Re: 310 in Oliver 77 in reply to VicS, 01-11-2019 04:23:09
Wonít the 77 bellhousing and clutch assembly also work?
VicS
01-13-2019 09:57:47
 Re: 310 in Oliver 77 in reply to 4010 puller, 01-11-2019 18:03:33
I'm sure it will. He did use a super 77 tub.
535353M
01-10-2019 16:31:37
I think so.
535353M
01-09-2019 13:04:16
oil filter issues,but maybe the same as moving steering,- I think.most cut the fan shroud for water pump room
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
