Super c rear hubs
mark20
Looking to replace the 36 rear rims and tires on my super c. They seem to be odd ball and I'm having a had time getting good used ones. I have a set of 11-38 which wouldn't look that bad. Just need to find a hub to fit the 2 5/16 ( which I think the super c is). Any ideas?
I was hoping to use a hub sorta like I did on my Super M. I used a Massey hub and center. I may have to go a different route. Thanks
The stock center with 6 bolts can be used
with 38s
Take the tabs off stock 36" rims and use
clamp stile rims from an Farmall H,M etc
and weld tabs on the 38" rims would be the
most reasonable unless you want to loose
some weight!
