9 bolt 38 wheels
I have a JD A with 9 bolt pressed steel
wheels will 9 bolt wheels say off a 1066 be
the say bolt pattern and fit on my jd hubs
or will any 9 bolt wheel fit thanks
They should fit just fine but, they should also be a heavier gauge and probably double thick at the 9 hole circle. What I'm saying is....they will weigh a little more.
yes,-- heavy duty can weigh as much as 75 # or more,bead area,centers and 9 bolt area can be double thickness.
