has anyone pulled at the Ozark Empire arena?
535353M I pulled one time there 2 years ago with a JD B. Track was short about 160 feet but got pretty good bite. Lynn
I've been there to watch several times and plan to be there Saturday......Seems to have a pretty good bite... A early hook might be an advantage as holes some times develop in a big class when they all spin out in the same place...I think 170 ft is a full pull?
Almost 4" of snow here but will be gone in a few days.
Facility is nice to pull in. If they water the track plenty it makes for a good track, if not spin to win. Big sled drops the pan or grousers at a certain spot so the trick is to time it so you open it up just as it hits. A big hole usually develops where everyone spins out. Going first after the speed classes is an advantage as they plow through the hole. They draw the numbers for you so you don't really get a choice in what order you pull.
