What happened Big Tee
I watched your 500 run strong all weekend at white pine and was extremely impressed with it but I saw you trying to roll start it Saturday night after your last run and it was just sliding the wheels. What do you think happened to it? Hopefully it?s nothing to major
At the pull everybody shares everything and we charge the battery between pulls. When I went to use my charger the plug ends were broken so the batt. was low and it wouldn't turn it over so we tried pull starting it. The compression ratio has been raised and it made the wheels slide. Some guy brought his booster over and it started right up. You should have stopped over and said hello--met a lot of nice people at the pull!---Tee
glad to know it wasn't a big issue, meant to talk to you but never did make it, haven't talked since I picked up the ole oliver several years back now
