Company Logo Shop Now
TractorLinks.com
Re: Rear weight mounts
VicS
10-11-2018 19:54:22
third party image
third party image
Will try to post a picture of my 435. It is the same as a 420 utility. Final drives are pointed strait back. I used short pieces of 1/4 x 3 bar stock. They are bolted to the bull gear covers with just 2-3/8 grade 8 bolts. I have 4 of these that would hold 2 each 90 lb. AC weights or 3-60 lb weights. Plus another angle iron welded to the drawbar. Which will hold 4 more 90lb weights or 6- 60 lb weights. I can pull 5000 lb but rear end won't take it. Or the engine. So quit at 4500. I also have a middle bar. Just 1/4 by 4 with a small angle iron welded to the back. Oh the steel is cold roll. Available everywhere. Hope this helps. Vic
johndeeregreg40
10-12-2018 03:55:47
 Re: Rear weight mounts in reply to VicS, 10-11-2018 19:54:22
Nice setup! Iíll see if I can use that design on my wheelie bars! Thanks!
VicS
10-12-2018 17:17:08
 Re: Rear weight mounts in reply to johndeeregreg40, 10-12-2018 03:55:47
Notice the hitch adjuster is not attached to the wheelie bars. The wheelie bars are 1" square tubing.
