chucksoliver77
my brother is in the process of building a 320 for his oliver 88. the machine shop recommends having bullet cams do the cam. how do you guys feel about bullet cams for olivers? thanks, chuck
(quoted from post at 21:09:16 03/08/12) Hey Chuck (or anyone else), ever run across any new 320 rod bearings?
jd, i don't know anyone that sells the 320 bearings but you could try brad at maibach tractor, 330-939-4192. chuck
(quoted from post at 16:41:51 03/08/12) my brother is in the process of building a 320 for his oliver 88. the machine shop recommends having bullet cams do the cam. how do you guys feel about bullet cams for olivers? thanks, chuck
huck, How big is he going? I am building one right now too, should be at 430 ci
(quoted from post at 17:29:13 03/09/12)
ere thinking around 450cu.in. think the bore will be 43/8", stroke still to be determined. chuck
Can you go 4.375 "safely" and still run water?
I have not decided on bore yet, I was thinking 4.280 or 4.310, and I will be at 5.00 stroke
