farmall h push rods,spark plug gap
redih
08-12-2010 18:52:38
waning to upgrade from stock push rods in a built farmall H any locations or suggestions on where to get them? Also running 350 piston kit with 175psi compression and 93 octane gas with champion d23 plugs what would be the ideal gap to set them to?
High octane
08-13-2010 05:27:15
 Re: farmall h push rods,spark plug gap in reply to redih, 08-12-2010 18:52:38
There are two different sizes for the H-350.
A skinny od set and a heavier, thicker OD set.
Unless you need something totally custom, you should have no problems finding the heavier set if you got the small OD set.
With electronic IGN, anywhere from .025 to .040 plug gap.
Points, up to .035 with a hot coil.
