NO TUBES
goatboy
08-06-2010 20:11:06
I have a set of 14 x 38 pressed steel wheels and 15.5 Firestones I want to try and go tubeless, has anyone had much luck without tubes?
johndeereman
08-08-2010 16:11:46
 Re: NO TUBES in reply to goatboy, 08-06-2010 20:11:06
i lost 150 lbs taking the tubes out of my 14.9's and i mounted them on 16 inch rims tough job but i got er did your 15 inch tires on 14 inch rims would be a breeze
Jackboot Johnson
08-08-2010 17:48:22
 Re: NO TUBES in reply to johndeereman, 08-08-2010 16:11:46
So you take the tubes out and then weigh in on an inaccurate scale the following year or even a different scale altogether and proceed to tell us two tubes for 14.9 x 38's weigh 75 lbs. each. Gotcha! I'd say they weigh more like 10-12 lbs. each but you're the smart one it looks like. Now, going by your logic, if I take my rain cap off my muffler and weigh in and just so happen to park in a different spot on the scale or the temperature is 30 degrees different from when I weighed in with the rain cap and I just so happen to weigh 60 lbs. lighter that means those damned rain caps weigh 60 lbs. huh? If that's the case then, we could just hang $10 rain caps on our pulling tractors instead of expensive suit case weights.
Jim Johnson
08-06-2010 20:16:23
It's no problem at all. When you get them mounted if they leak just put some Slime in them and you're good to go, saves a lot of weight.
Jim
indianared
08-08-2010 09:12:56
 Re: NO TUBES in reply to Jim Johnson, 08-06-2010 20:16:23
Just curious, how are you saving weight? Just the tube themselves?
Jim Johnson
08-08-2010 20:07:57
 Re: NO TUBES in reply to indianared, 08-08-2010 09:12:56
Yes sir just the tubes themself. A 18.4X38 will a lot of the time lose 35 LBS. a tire.
