Need to loose about 15 Hp
Mike S 806/H
07-24-2010 17:06:11
I need to loose about 15+ Hp, pull is 8000# class and only 80Hp, Tractor is a 460 Farmall with a 301ci engine, any ideas?
NCWC
08-13-2010 12:09:41
 Re: Need to loose about 15 Hp in reply to Mike S 806/H, 07-24-2010 17:06:11
If you need to get rid of 15HP I will gladly take it .. hahaha Sorry had to say it!!!
Drew
07-25-2010 20:15:17
I will 2nd the MSD timing control. It makes it easy to change from your dead tuneup to the full power tuneup.
High Octane
07-25-2010 17:14:47
The restrictor plate idea works. Been there done that, still do today!
If you got the #35 venturi, then go back to a 27 or a 29.
Kinda the same thing as the restrictor plate idea.
Your restricting the amount of air that enters the engine, which will cut your high rpm power range, but you might pick up lugging power with the smaller carb setup.
CJ_1080
07-25-2010 12:01:46
Hmmmm..... . this is a first!!! You could retard the timing. Or fatten up the carb. Maybe restrict the carb or drop the rpm's. I had to really think!!! Usually my mind works the other way.
James Rumph
07-25-2010 03:54:09
Do you have access to a dyno ?
Air filter placement [distance] from carb is worth around 5hp.
The rpm that you run the motor at. On a "M" anything over 1900 and you run out of cam lobe .
Timing is worth 5 to 8 hp .
This is a tuff one because anything you do will effect the big picture.
When they go to put you on the dyno why don"t you pull the choke on half way or more . I"m thinking that should faten the motor up enough to take some "HP" away.
You could also put a electral switch in that full fields the alt ,at all rpm causing a nice load on the motor.
This is the first time i have read some one wanting to loose hp.
Maybe you should have asked how to hide HP , there is plenty of people on hear that cheat like crazy for that $10.00 trophy.
Intresting question , nice for a change.
Hope some of my thought help out.
Mike Bock
07-24-2010 20:43:03
a restrictor plate on carb will lower hp but you will still have the torque
dblair
07-24-2010 19:30:27
they dyno the winner ?
Mike S 806/H
07-26-2010 07:18:09
 Re: Need to loose about 15 Hp in reply to dblair, 07-24-2010 19:30:27
Yes, top 3
jd hauler
07-24-2010 19:10:35
msd timing control
