C301 carb options
C301 puller
07-13-2010 14:59:36
I have a stock bore and stroke c301 I was wondering what carb is best to put on it.I'm going to be running 2650 rpm's in a stock class.Will the stock distributer be ok or should I upgrade to something better?Will an lp manifold be worth the money for my setup?Thanks
farmall460ih
07-14-2010 14:46:36
 Re: C301 carb options in reply to C301 puller, 07-13-2010 14:59:36
go to your junkyard and find a ih 715 combine and take the carb off it. disable the electronic shut off... make sure it has a #35 ventouri in it and your good
