Horsepower Requirements Div2 and 3???
Mopower
06-23-2010 09:04:57
Usually I like to break everything down into torque ratings, but for discussion's sake, I was wondering what horsepower was required to be competitive in Div 2 or Div 3 classes at different weights. (Just say moderate rpm like 1700-1900 range.) I have a good idea, but it's fun to keep ears open and see what folks think. Thanks.
560 Farmall puller
06-25-2010 19:10:58
 Re: Horsepower Requirements Div2 and 3??? in reply to Mopower, 06-23-2010 09:04:57
Here in Ohio a lot of the Div 3 have went back to Div 2 so the there are a LOT of 100 hp plus engines running in that class. You need 150 or more to be competitive in Div. 3 more like 200.
Mopower
06-25-2010 20:19:47
 Re: Horsepower Requirements Div2 and 3??? in reply to 560 Farmall puller, 06-25-2010 19:10:58
What weight?
kody s
06-27-2010 10:48:24
 Re: Horsepower Requirements Div2 and 3??? in reply to Mopower, 06-25-2010 20:19:47
4000 to 6500 Div.4s and 5s going to Div.3 and 3s to 2 and 40 to 70hp 2s are staying home.
James Rumph
06-24-2010 19:44:38
I"m not sure your going to get the answers your looking for !
I"m going to take a stab at it and say.
Div 2 60 to 90 hp.
Div 3 as much as your wallet can afford...
Tractor set up is just as important as the power.
MLPANKEY
06-23-2010 16:56:17
Mopower said: (quoted from post at 09:04:57 06/23/10) Usually I like to break everything down into torque ratings, but for discussion's sake, I was wondering what horsepower was required to be competitive in Div 2 or Div 3 classes at different weights. (Just say moderate rpm like 1700-1900 range.) I have a good idea, but it's fun to keep ears open and see what folks think. Thanks.
200 HP at rated pto rpm should work anywhere
Bryce
06-29-2010 17:50:01
 Re: Horsepower Requirements Div2 and 3??? in reply to MLPANKEY, 06-23-2010 16:56:17
@ 200 rated PTO? Which one on these oldies PTO can take that to find out?
LCB
06-23-2010 15:44:19
You beat me but I think you where just lucky.When that uguly green beats red it has to be luck. Leroy
VicS
06-23-2010 20:31:16
 Re: Horsepower Requirements Div2 and 3??? in reply to LCB, 06-23-2010 15:44:19
You at least beat that other shade of green.
630rich
06-23-2010 15:12:02
I agree to the balance and traction being the most important thing.I pull a stock 630 in 8500 and 9500 farm stock 5mph class and always finish in the top 5 or so. put your power to the ground and you will be competitive.
VicS
06-23-2010 12:25:17
So I guess we are talking 3 to 4 mph. I just have experience in the 3500 to 4500 classes. I think I have 65 hp. In a 435jd or 2-53 detroit or 106 cu in I pull in 1st gear and It doesn't go but 4.5 mph no load speed. And I will maybe scare some really powerfull tractors, even in the 6 mph class. I powered out last pull at Ramsey Il. in the 4500. but still got 2nd. There was maybe 10 in that class. What I'm saying is, Its not all hp but the right tires and balance.
wonderingabout#s
06-29-2010 14:39:05
 Re: Horsepower Requirements Div2 and 3??? in reply to VicS, 06-23-2010 12:25:17
i don't know div.'s, but i know in a 3mph and under 6000lbs, u can do it with 50 hp and be in there, and 65hp up to 8000lb, then 80+ on up to the 13000. if you wanna go 6+mph, you need to get in the 100hp range in the 6000 and under, and 150hp for anything else from what i've seen. all with 16.9 or 18.4x38's
