copper head gasket leaking???
DOYLL
06-14-2010 10:34:10
Does any one no of any thing to put on a copper head gasket to keep it from leaking watter? It is just leaking a little water around the outside,but quit's after it get's warm. The block has been O-ringed and I sprayed the gasket with permatex copper coat and nothing is getting in the oil just leak's on the out side.Or is there something I can put in the watter that might seal it?
730-LP
06-14-2010 14:58:47
 Re: copper head gasket leaking??? in reply to DOYLL, 06-14-2010 10:34:10
If its only to the outside JB Weld makes a product called water weld, just break a piece off and work like play doe and apply to the leak,it will work with water leaking out.
2-lunger
06-14-2010 13:14:41
Moroso ceramic engine sealer,used it alot on dirt latemodel engines works great
