Losing WEIGHT on a Farmall M
unknownm
06-10-2010 13:33:43
I need some ideas, I already have tin rims, weld on hubs a really light hitch,wheely bars and seat stand. Need to lose 200lbs quick but need to stay farm stock
CoopertownBob
06-16-2010 21:16:18
 Re: Losing WEIGHT on a Farmall M in reply to unknownm, 06-10-2010 13:33:43
How much do they run? I may need one on my H.
TMCC
06-16-2010 21:41:35
 Re: Losing WEIGHT on a Farmall M in reply to CoopertownBob, 06-16-2010 21:16:18
Call me to discuss!
TMCC
06-16-2010 20:46:23
I Cast aluminum trans covers that look original.
They weigh 50 LBS and are drilled and machined.
417 766-8834
Weight_Watchers
06-14-2010 06:49:42
Try a single wheel front end. Good for around 50 pounds total with the smaller tire.
MKA
06-11-2010 19:36:37
what are you at now for weight ?
jake renner
06-11-2010 19:16:05
get a hold of adam camm for a trans top. you can lose 100 lbs easy. also make a front end out of a piece of pipe and a lighter spindle/hub assembly
Bouncer
06-10-2010 21:15:59
I assume you already have the belt pulley off and hydro pump out?
unknownm
06-11-2010 03:38:57
 Re: Losing WEIGHT on a Farmall M in reply to Bouncer, 06-10-2010 21:15:59
yes the belt pulley and hydro is gone
flambeauone
06-10-2010 16:39:19
Look into a lighter weight front bolster.Machine off the excess from anything cast that you can get into a mill(transmission top cover,gas tank mount etc).
