460 hydraulic compartment
i460h
05-25-2010 19:15:15
still working on the 460 puller.. pulled the hydraulic pump and all the filters and screens. just wondering how we could seal that section off so we don"t have to have as much rear end fluid. just wondering what people have done before to do this... how little of rear end fluid can you safely run in it? any help is great
460 puller
05-25-2010 20:28:42
 Re: 460 hydraulic compartment in reply to i460h, 05-25-2010 19:15:15
measure the holes & get freeze plugs. 5gal. is plenty if you use a empty 2gal. jug between the bull gears with a stick to hold it on bottom. Good Luck
i460h
05-26-2010 13:27:12
 Re: 460 hydraulic compartment in reply to 460 puller, 05-25-2010 20:28:42
i found the hole on the right side of the tractor under the filter cover going towards the rear end... is this the only hole i need to plug... i have never thought of the 2 gal jug idea though. thanks
460 puller
05-26-2010 20:13:28
 Re: 460 hydraulic compartment in reply to i460h, 05-26-2010 13:27:12
you have to split the tractor between clutch housing & tran. look at IT shop manual paragraph 213 fig. IH1164. At the top, there is a drain gutter to remove. Wile your there you might as well take out the PTO parts out, Remeber Go Big or Go Home
i460h
05-27-2010 12:43:14
 Re: 460 hydraulic compartment in reply to 460 puller, 05-26-2010 20:13:28
we want to keep it in the working pto class for now but thank you so much...
