Farmall M Cylinder head
Koeda
05-03-2010 16:00:46
I have a 1941 M with a cracked head. The head number is 6336DD, do I have to replace it with the same number or will any head fit?
pafarmall
05-04-2010 18:38:10
 Re: Farmall M Cylinder head in reply to Koeda, 05-03-2010 16:00:46
The 8060 casting number is that off an M, Super M or what originally? What would be the casting number off a 450? How come no one is making aftermarket aluminum or better quality cast heads today for M's or are they? thanks.
D Slater
05-04-2010 05:46:30
Any gas head for a M through SMTA would be a help on power and bolts right on. Think the head you have came with 3/8 studs to hold the manifolds on. Later and most used 7/16 studs.
third party image
This post was edited by D Slater at 06:04:36 05/05/10.
D Slater
05-04-2010 05:54:53
 Re: Farmall M Cylinder head in reply to D Slater, 05-04-2010 05:46:30
400 450 heads dont have the opening you can see at rear of head. Pipe to air cleaner inlet. They can still be and are used on the M.
third party image
This post was edited by D Slater at 06:08:59 05/05/10.
red pullen
05-04-2010 03:28:09
i have an m head ported and polished valve job ready to go call me 937 539 8199
SUPER TRUCKER
05-03-2010 16:09:26
IF YOUR GOING TO PULL OR HAVE A ALL AROUND FUN TRACTOR LOOK FOR A 450 HEAD. WAY BETTER THEN A M HEAD BUT THEY ARE EXPENSIVE. OR YOU COULD GO WITH A M OR S M HEAD FOR A LOT LESS.
