jd 720 diesel question
jdiesel
05-02-2010 12:16:25
taking rock shaft housing off of 720 diesel, div 3 tractor. to look at it we are loosing alot of strength on the axel housing. thought of making a steel gurdle to go behind the diff cover to add support to the rear end when under a heavy pull. would like some opinions please. don't want to waste the time if not needed.
2 TIMER
05-02-2010 18:00:23
 Re: jd 720 diesel question in reply to jdiesel, 05-02-2010 12:16:25
I HAVE A 730 I TOOK ROCKSHAFT UNIT OFF PUT ON A FLATBACK WITH THE LOOP INCORPERATED IN THE FLATBACK NO PROBLEMS,,,
buickanddeere
05-02-2010 12:24:09
Take the rocksahft internals out and install just the bare housing. Plug the holes with wooden plugs.
