Need Help-pistons
RTO
03-29-2010 18:49:29
Im building my 273 Buda for my 50 Cockshutt and im putting the D-19 Allis Crank in it for a 3/8 inch longer stroke and of coarse a bigger custom made cam,etc. A looked it up in a book that a 250 inline 6 chevy has a 3 3/4 bore just like the 273. But can some one tell me about resist pin height? Are the rings in the same spot? Is it shorter or taller than a standard 273 piston? I want to try and stay away from custom made pistons cause the budget is alittle tight but if someone out there has done the same thing as what im doing if they would want to share with me I would really appreciate it. Thanks in advance.
snappy
03-31-2010 05:11:28
 Re: Need Help-pistons in reply to RTO, 03-29-2010 18:49:29
i have what you need please call me at 716-308-5987
RTO
03-31-2010 09:10:27
 Re: Need Help-pistons in reply to snappy, 03-31-2010 05:11:28
Snappy, Thank you for leaving that message on my phone, i will give you a call back probably about mid afternoon. Once again thank you.
JDGnut
03-29-2010 19:27:32
Is there enough material above the top of the pistons rings to machine the tops down and use the stock.. or stock style piston??
RTO
03-29-2010 20:04:47
 Re: Need Help-pistons in reply to JDGnut, 03-29-2010 19:27:32
Im not really sure i have a 230 Buda in it now and a 50 is suppose to have a 273 in it. im getting a block but as far as pistons im not sure.
RTO
03-29-2010 18:52:07
Also How big of a bore can I get out of that 273? Thanks
