Custom wide front end for Super M
James Rumph
03-24-2010 16:51:11
I have seen many pictures of custom wide front ends on International "M" based tractors.
I have been wanting to make one but what hubs and spindels , tie rods etc etc are people useing to put five lug wheels on.
Any pictures would also help . This is just a pulling tractor so a factory wide front is not wanted .
Light weight is the name of the game here.
Rich R.
03-25-2010 16:36:11
 Re: Custom wide front end for Super M in reply to James Rumph, 03-24-2010 16:51:11
Ive seen some guys running the front axles off running gears lately. Seems if you found the right one and cut it to your liking it would give you your bolt pattern and be fairly light. Just sounds like a cheap alternative if your handy with a torch & welder.
James Rumph
03-26-2010 15:03:47
 Re: Custom wide front end for Super M in reply to Rich R., 03-25-2010 16:36:11
Running gear ?
ih560
03-26-2010 18:59:50
 Re: Custom wide front end for Super M in reply to James Rumph, 03-26-2010 15:03:47
James Rumph said: (quoted from post at 15:03:47 03/26/10) Running gear ?
I am pretty sure he means running gear, like what is under a farm wagon or gravity bed.
haird_350
03-24-2010 19:48:03
My widefront is built for an A Farmall Axel. We cut the hubs off and used some spindles and hubs from a trailer axle which can be picked up at tractor supply. For the steering we used a manual rack and pinion from a pinto or mustang two and made the tie rod ends. As far as mounting goes, I mounted the axle solid. Hope this helps.
VicS
03-24-2010 18:58:23
I built one from a sprint car, plus you get knock-off wheel"s. They always have a bent one. It is so light you can lift the axle and wheels with one hand. I braced it with used oil-field pump barrel. It is as good a pipe as they make, and is free.or almost.
dblair
03-24-2010 18:22:10
third party image
take a look at this design , strait spindles and raised pivot this is simple and light
J clark
03-25-2010 11:03:44
 Re: Custom wide front end for Super M in reply to dblair, 03-24-2010 18:22:10
hey thats a cool lookin v8 where co you guys pull i have a v8 oliver super 88 with a ford fe motor in it we pull up in the thumb of michigan
dblair
03-25-2010 16:04:11
 Re: Custom wide front end for Super M in reply to J clark, 03-25-2010 11:03:44
middle of Va. near Appomattox. go to cvatpa.com and look at our pictures
dblair
03-24-2010 18:15:16
I've seen box tubing used for the tubes but just one tube and it was only 3 foot long. don't know what they used for the spindles but I'll look at the next pull . 4-17-10
