MORE FUEL
LUCKY ONE
03-06-2010 12:24:39
LOOKING TO GET MORE FUEL OUT OF MY 560 D. PUMP IS MAX OUT ON FUEL WITH STOCK HEAD . PUSHING AROUND 130 HP RIGHT NOW WITH A TURBO
4010 puller
03-07-2010 04:36:17
 Re: MORE FUEL in reply to LUCKY ONE, 03-06-2010 12:24:39
What are your numbers on the injection pump? You need a bigger head/rotor for pump as well as bigger injection lines and lazered injectors. I can get you names of guys if you need them for parts suppliers.
LUCKY ONE
03-07-2010 16:38:21
 Re: MORE FUEL in reply to 4010 puller, 03-07-2010 04:36:17
DB6FC631-1AE 42909E 278346R91 HOPE THIS HELPS
4010 puller
03-08-2010 03:44:56
 Re: MORE FUEL in reply to LUCKY ONE, 03-07-2010 16:38:21
631, that should be 6 cylinder 31 head/rotor. They made a lot of different ones but if youre only going to tractor pull it and youd like the most power, go with a 39 or 45 head/rotor. There are some problems with seizing pump shafts on the 45 head/rotor, but if you size the injectors and lines right, you shouldnt have as much trouble. Call JP (In Indiana) at 812-243-8305 .
LUCKY ONE
03-07-2010 15:19:50
that would b great ill get the numbers of pump. it has stock lines and injectors now
