5.125 GMC Pistons
Ydlewyld
02-23-2010 09:47:50
Any body know where I can get a set of four 5.125 GMC gas pistons?
THANKS in advance
Ydlewyld
02-24-2010 10:27:03
 Re: 5.125 GMC Pistons in reply to Ydlewyld, 02-23-2010 09:47:50
Thanks I have found what I need thanks for the help
jd b puller
02-23-2010 17:03:52
Do you actually need that exact piston, or do you want it because it's close to what you want and you can modify it to end up with what you want?
gomo
02-23-2010 10:09:56
They have been unavailable for about 15 years. An old wharehouse or someone who buys up old stock is your onlyhope.
Cody Adgent
02-23-2010 13:49:30
 Re: 5.125 GMC Pistons in reply to gomo, 02-23-2010 10:09:56
What engine did they origianlly fit it?
jd b puller
02-23-2010 15:09:58
 Re: 5.125 GMC Pistons in reply to Cody Adgent, 02-23-2010 13:49:30
478 GMC Truck motor.
Another low cost option is the Lycoming 320/360 aircraft piston. You can find them used for 20 bucks or less. Rings are pricey, keystone ring.
