Farmall H 9 speed trans.
M Hoffmann
02-18-2010 17:51:30
Is the M&W 9 speed trans any good for pulling and how are the gear splits is 1st the sam speed or is it slower any info would be great. Thanks Mike
CJ_1080
02-18-2010 19:45:14
 Re: Farmall H 9 speed trans. in reply to M Hoffmann, 02-18-2010 17:51:30
If I remember right the 9 speed's extra gears are between 4th gear and 5th gear (road gear). So 1st through 4th stay the same. Personally I'd use a different tractor for a puller or ditch the extra gears (if thats possible). Less overall weight=more moveable weight.
superih
02-18-2010 19:07:20
High range starts at 4th low and goes up in speed. So to put gears in order; 1L, 2L, 3L, 4L, 1H, 2H, 3H, 4H and then 5 gear (road gear).
