jd 620
mkr100
01-22-2010 19:10:16
What tires will hook a 620 up ? Having trouble with a 560 and a 450 that are so called stock. 18 inch drawbar 3 and a half foot chain.7500-8500 classes
jd plowboy
01-24-2010 18:51:49
 Re: jd 620 in reply to mkr100, 01-22-2010 19:10:16
i have a 620 bone stock and have 18.4x38 firestone field and roads and the only classes i can get it to hook up in are 9500 and 10500 but i had to fill the tires with water to make it hook. with the low first gear it would spin out everytime
Mike n Mo
01-23-2010 06:39:08
Why don't you look at the tires that are beating you? For that weight class I'd use 18.4X38's. Look for a set that has 3/4-1" tread, old/hard and a reasonably sharp edge on them. I'd avoid the Goodyear "crooked bar" tires, never saw them work at all. Mike
630rich
01-22-2010 22:05:13
16.9x38s, keep the front down, and put it in 1st gear and let it putt! How is the motor on power?
