dist advance
heavy hauler to
01-22-2010 14:54:23
I don't know if my dist has been recurved or not. I think it has the firecrator mod, Changing timeing dosen't seem to change anything. I* would say it is in the neighbor hood of 10 to 1, thanks.
MLPANKEY
01-23-2010 16:00:56
 Re: dist advance in reply to Cody Adgent, 01-22-2010 14:54:23
ChadS said: (quoted from post at 15:02:36 01/23/10) Nope.
I beefed up the stock IH 2 bolt. Ratchet bendix instead of springed recoil on my mod.
Special brushes,,,,, ,,,
Are you going to run a WC mag on that one you got?
ChadS
NO msd all the way
ChadS
01-24-2010 10:59:01
 Re: dist advance in reply to MLPANKEY, 01-23-2010 16:00:56
Does your MSD think for itself, or still using the manual dial to control timing?
Electronic technology gives you the ability to eliminate the distributor, and that is old news now,,,, but an ECM thats set off a laptop, and self compensates as it goes,without the laptop, records data, then with a modified desk top dyno program, go back and tweek to perfection,,
would be very popular. It's been done by now, but how primitive of a system it must have been!
ChadS
mlpankey
01-22-2010 17:09:06
 Re: dist advance in reply to heavy hauler too, 01-22-2010 14:54:23
lock the advance out and run total timing.
ChadS
01-23-2010 07:14:23
 Re: dist advance in reply to mlpankey, 01-22-2010 17:09:06
Base timing + advance timing, no more than 40 degrees total.
In midseason 2008, my points came loose, I needed a quick tune up, I had a spare dizzy, so I swapped it.
It didn't run right, Lazy,,, so I borrowed a digital timing light and checked it.
Base was 20. Upon accelleration, it spiked to 60 degrees, then fall back to around 35 when the rpm peaked.
I found the dizzy that the points loosened up in,,, took it apart,
along with the one I was running at the time,,,,, ,
Well, the first dizzy was a 16 degree advance unit,
The second was a 40 degree.
Went back to the 16 degree,,,, stock advance springs,
Night n day difference!!
It now sees a 36 peak, But, I brought it back to 30 by readjusting the base timing.
I swapped the advance springs for a lighter set,
I watched the timing light under accelleration, It peaked timing at 30, right before peak rpm.
So my timing was done adjusting, before my peak rpm arrived.
On a 40 degree dizzy, the timing advance total travel is quite a bit, but, it floats,, or hunts,,, its not consistant, you get a different reading everytime!
Another symptom was, The base timing adjustemnt, never seemed like it changed the timing any,,,, so I knew the advance was floating,,, Hunting so to call it. Hope this helps.
I wouldnt lock the advance on a Farmall. With so many selections of distributors, It's easy to sort once you see what its doing with a digital timing light. I would not wanna fire up my engine with it locked in at over 30 degrees timing,, in 30 degree temps or less,,, Might be considered rough on the old H,,,,, LOL!
Chad
mlpankey
01-23-2010 08:57:47
 Re: dist advance in reply to ChadS, 01-23-2010 07:14:23
Chad you must not have a gear reduction starter on that h?
ChadS
01-23-2010 14:02:36
 Re: dist advance in reply to mlpankey, 01-23-2010 08:57:47
Nope.
ChadS
dblair
01-22-2010 15:53:52
watch it with a timing light to see if it's advancing and how much
