super H
josh todd
01-13-2010 04:59:59
do any of you pull with a a super H what are some good things to do to it to get more power i have just about finished the rearend and was trying to figure out a gameplan for the motor i dont want to go to extreme because i do plan on using it but i still want to be a competitive puller just looking for a few pointers
josh todd
01-14-2010 18:16:35
 Re: super H in reply to josh todd, 01-13-2010 04:59:59
what kind of head does he run on his super H and where did you have your cam done?
Andrew Z
01-16-2010 18:31:57
 Re: super H in reply to josh todd, 01-14-2010 18:16:35
The head is a stock head that has been decked. The cam was done by Berrys. let me know if you need more info email is open
Andrew
Andrew Z
01-13-2010 09:53:56
my father pulls stone boat a Super H, his is a low gear tractor so power is not as critical. However what we have done to the tractor, electronic igniton, drilled out carb, decked the head, over sized fire crater pistons (3 5/8"), Cam work. Nothing to extreme at all but does make for a pretty snappy tractor. Able to pull from 4500 - 7500 classes. Alot depends on what kind of pulling your doing and how much you want to spend.
Andrew
