Aftermarket water pump for John Deere G and A
Brent50G
01-12-2010 09:50:39
I’m trying to locate a water pump like this one in this ad. >Link
Does>Link anybody know anything about these aftermarket water pumps like who made them or where to locate a setup like this? Thanks for the help
supperpuller
01-13-2010 17:29:27
 Re: Aftermarket water pump for John Deere G and A in reply to Brent50G, 01-12-2010 09:50:39
I have a complete pump, fan shaft bracket, and all water line fittings every thing in the picture you listed. If interested email me and i'll give you my #
JDGnut
01-13-2010 10:49:03
 Re: Aftermarket water pump for John Deere G and A in reply to Kodg, 01-12-2010 09:50:39
This is the pump we have used, the last one I bought was $30-40 less, but its been a few yrs ago.. but I kind of like the one bpuller listed..
Link
There is also an electric pump that will work in line with bigger radaitor hoses.. some of the truck guys run them.
I've never seen one like you listed... I know that some of the old M&W kits had a water pump with them.. (or maybe it was an option..) but I thought it came with a lower radaitor tank with the pump (like a 70) but maybe it was the one that was shown... Its been a while...
JDGnut
jd b puller
01-12-2010 19:16:43
Brent, how about something like this?
mdm
01-13-2010 17:35:41
 Re: Aftermarket water pump for John Deere G and A in reply to jd b puller, 01-12-2010 19:16:43
Ray, have you used that water pump? If so, what are your thoughts?
jd b puller
01-13-2010 18:16:57
 Re: Aftermarket water pump for John Deere G and A in reply to mdm, 01-13-2010 17:35:41
mdm, I actually use the one off the F150 Lightning on my B. Total cooling system is just under 3 gallons. I've never had a problem keeping it cool. Aluminum rad, elec fan and that little beer can water pump.
Starting to Build a 1000+ inch G, the pump shown should do the trick (20GPM).
