16.9-38s
mkr100
12-29-2009 17:45:24
Whats the best rim width for 16.9-38s ?
JDTH
01-01-2010 08:00:29
 Re: 16.9-38s in reply to mkr100, 12-29-2009 17:45:24
Running 16" rims with 16.9's & 19" rims for 18.4's. Typically run a good amount of air pressure, depending on the track. Don't like the drop in hitch height with lower pressure.
Vic S
12-29-2009 19:48:49
I don"t think any body knows, I have 18.4 mounted on 16 and 18 I have done better with the 16 You have to use more air pressure with a wider rim. I think you can make any combo work if you play with the air pressure. Most pullers don"t use enough pressure. If your tractor settles 2inches as you are pulling you are are in effect using a 18 inch drawbar instead of a 20 inch.
Vic S
12-29-2009 19:48:48
