18.4-34 or 16.9-38
East Tn Oliver
11-17-2009 21:03:24
Sorry I'm asking so many questions but which of these two tires (18.4-34 or 16.9-38) would be the best for pulling that is?
jd hauler
11-18-2009 18:00:29
 Re: 18.4-34 or 16.9-38 in reply to East Tn Oliver 77, 11-17-2009 21:03:24
I would stay with a 16" rim, especially if you pull where there are rim limits, sometimes rules say tire must be mounted on the rim size on the tire or no more than one inch wider, to make a set of 17's or so would be alot of work for very little result, IMO
Vic S.
11-18-2009 17:45:35
You guys bigger is always better.
Michael Locher
11-18-2009 09:26:23
16.9-38 i think has to have atleast a 14-38 wheel
alot of boys i pull with run 18.4-38 on the 18-38 wheel i like running which ever wheel supposed to fit the tire
Doogie dog
11-18-2009 08:37:36
YOU RUNNING OPEN GEAR OR 4MPH?
East Tn Oliver 77
11-18-2009 08:51:10
 Re: 18.4-34 or 16.9-38 in reply to Doogie dog, 11-18-2009 08:37:36
I'm not running anything right now. I'm working towards open gear.
Mopower
11-18-2009 05:22:08
On the "ideal" prepared track, 18.4 may have an advantage if cut correctly for say 5500# and up. I pull agressively cut 16.9 X 38 in 5500# and can compete with the best considering my lack of horsepower. Some M's are doing well in 4500# with 18.4, but I've also seen 16.9/15.5/14.9 beat them in a traction fight. I would say for 4500# you get better downpressure on a narrower tire and this is good if you are fighting for tracion on local scrub tracks. But if it is a true "power track" 18.4 is the way to go if you have the gear and power.
Joe Hoover
11-18-2009 04:53:23
I had one set of each mounted on pressed steel at one time same brand same ply and everything the stood identical height but the 18-4's were wider dont know why but the 16-9 rubber always worked better no matter the track conditions were runnin anywhere from 5500 to 8500 lbs hope it helps you some
East Tn Oliver 77
11-18-2009 08:43:26
 Re: 18.4-34 or 16.9-38 in reply to Joe Hoover, 11-18-2009 04:53:23
Thanks guys! I think I will go with the 16.9's. My next question is what width rim should I use?
Mopower
11-18-2009 10:33:24
 Re: 18.4-34 or 16.9-38 in reply to East Tn Oliver 77, 11-18-2009 08:43:26
Our 16.9 Firestone Deep Treads are on 17" rims. It makes that thick stiff sidewall stand right straight. Seems to work well, but Deep Treads are quite square with long bars compared to some of the new jelly donut balloon round squishy tires. I have yet to try my 16.9 X 30 on 17".
