How long to harden
rrlund
Implement enamel, sprayed on without a hardner. How many weeks should it dry before I attempt to sand down some major paint runs? I really don't want to clean it back to bare metal and start over, but I don't want to leave this mess like it is. I figured I'd use some real fine sand paper after it hardens good, then try to blend it with a buffer, and if that doesn't do it, spray another coat over it. More carefully next time.
Sure glad I'm not trying to make a living doing this.
The longer you wait the better. Putting it out in the summer sun will speed the drying process. I'd wait until you can't easily make a mark in the run with your fingernail.
Better let the paint dry a month before working on runs. Use a straight edge razor blade and shave the majority of it off before sanding. You can completely sand the rest of the paint off before you level a run otherwise.
Thanks a million Glennster. I knew you'd have the answer. I just ordered one off Amazon since the nearest place that has one is 35 miles away.
When you don't use the hardener, and you have to break the skin off of the paint with a razor blade, sandpaper, buffing, etc to "remove" a run the paint in that area it will no longer be durable unless you plan on applying another top coat over the entire part.
(quoted from post at 14:42:37 07/21/23) When you don't use the hardener, and you have to break the skin off of the paint with a razor blade, sandpaper, buffing, etc to "remove" a run the paint in that area it will no longer be durable unless you plan on applying another top coat over the entire part.
Once you "break the skin off" the paint underneath quickly hardens as the solvents are able to evaporate.
Well, the run razor probably works if the paint is dryer, but all it wanted to do was gum up on the blade. I ended up pouring some thinner in a can, tossing in some shop rags and rubbing the whole grill back down to bare metal and repainting it. It would have saved me a week of messing around if I had just done that right from the start.
(quoted from post at 05:51:17 07/25/23) Well, the run razor probably works if the paint is dryer, but all it wanted to do was gum up on the blade. I ended up pouring some thinner in a can, tossing in some shop rags and rubbing the whole grill back down to bare metal and repainting it. It would have saved me a week of messing around if I had just done that right from the start.
I assumed that those run razors worked on soft paint. This is good information!
if the paint is wet the razor will not work. if you catch the run while you are still shooting or immediately after, you can pull the run off with a
loop of masking tape, it takes a little finesse but you can get the run down and dust back over it.
