Question about painting a JD 44 plow
DBS
New User
I'm restoring a JD 44 plow that I recently purchased. Primary use will be annual plow day, maybe a small amount of plowing in addition to the plow days, and perhaps displaying at tractor shows. The metal is almost complete rust and I'm disassembling and cleaning the rust using a wire wheel, then wiping with brake parts cleaner. I follow that with a coating of ospho, letting it dry several days, then priming with a self etching primer. The metal is pretty pitted, so I'm not looking for a shiny finish. I've read several pages on this forum and have a better idea of how to proceed, but do have a few questions. I've settled on the Rustoleum tractor and implement paint since I've read it holds up pretty good. I'm spraying the primer but plan to brush the base coat. I tested one small piece this afternoon using a foam brush and to be honest, can't really tell it was brushed. It does look a little lighter shade than a few places I've found green paint such as on the underside of bolts, but I suppose it will do. My main question has to do with adding hardener. I'm aware of the hazards and the need for supply breathing air to be from a different area, but do is the hardener safe to use if I'm brushing? Maybe using a respirator to protect from fumes? Will the Rustoleum paint be hard enough to not really need to worry about using the hardener for the use I'm planning for? It will probably be left outside, so I was wondering if the hardener would help with the paint fading. My default plan is to do the rest of the parts I've got primed without hardener and continue to use a foam brush unless you guys think I need to change coarse. Thanks.
The hardener they make for an alkyd enamel is a lot milder than what is used in urethane. You can use a cartridge type respirator with that hardener just painting a few tractors. It would take occupational overexposure using it daily before it would hurt you.
Thanks guys. I'll get some hardener today and mix that in for the rest of the project.
After I painted a few of the parts (levers and hitch assembly), I thought the green looked too bright, so I stopped by the JD dealership and bought a quart of classic JD green. Can I paint this directly over the Rustoleum tractor and implement paint or do I need to prime over it, sand it, or do something else? By the way, I did not use the hardener. Thanks.
This post was edited by DBS on 05/31/2023 at 02:24 am.
After I painted a few of the parts (levers and hitch assembly), I thought the green looked too bright, so I stopped by the JD dealership and bought a quart of classic JD green. Can I paint this directly over the Rustoleum tractor and implement paint or do I need to prime over it, sand it, or do something else? Thanks.
I painted my son's JD 55 ABH plow back in the winter once he finished cleaning it up as you are doing with a wire wheel on grinders and drills. What I did was use the JD primer,let it dry, then scuffed it up a bit. The green is JD brand and was mixed at 9 Oz with 1 Oz of hardner. All of this was sprayed on using a siphon style paint gun. It all turned out very well. The hardner will give it more gloss and be more withstanding longer, especially if left uncovered.
