Window gaskets
molinegb
Anyone recognize type of window opening with double lip. Looking for gaskets.
Check with Steele Rubber Products. They make a lot of stuff which is model-specific and also some products for general applications. Specifications and cross section dimensions are available online.
Try Restoration Specialties. That is where I sourced weather stripping for an old snow cat that I was working on a few years ago. They give you a cross section of every type which helps a lot.
Give us a clue as to what the cab is off of. You may have to have new glass cut and glued in like they do windshields now
(quoted from post at 08:27:00 05/25/23) Anyone recognize type of window opening with double lip. Looking for gaskets.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto155265.jpg>
Did you look at restoration specialties??? As I posted earlier they have cross sections for all their moldings and weather strips as you have sketched.
Yes stop by at your local glass shop. You might look into a rubber seal for the frame and then glue the glass to the seal. That is how we got the windshield to quit leaking on a then new Frieghtliner.
